I am a new homeowner and am relatively handy. I have worked in building maintenance at a hospital, but I am not entirely familiar with the electrical codes.
I was meaning to replace a faulty outdoor outlet but discovered that the metal box (no backing to it) that housed the outlet was attached to a plastic box in an exterior wall (transitioning from Romex). Additionally, this outlet then leads into a PVC conduit (possibly just PVC pipe) containing more Romex that ultimately goes a couple of inches underground traveling about six feet, leading to another outlet and floodlight in an inconvenient location.
I suspect that I am dealing with the work of the previous homeowner rather than an electrician. I have a few questions about this:
Is the transition from Romex to a PVC conduit correct? I asked someone at Home Depot and was told it was correct. Common sense suggested that it would at least potentially allow water into the wall without some kind of flashing, adhesive, and / or silicone.
Is it allowable to run Romex in PVC conduit or pipe? I know that you can’t do that in EMC but not sure if it’s also the case for PVC. Also, is there any difference between pvc pipe and pvc conduit?
If I had to redo the conduit to the floodlight and outlet, would I need to use PVC conduit (or some weatherproof application) and would it need to be “underground” a couple of inches as opposed to just running it on the ground next the exterior wall?
