I have a circuit in my home that started periodically tripping recently. I have tested removing each appliance one-by-one, but even with everything removed it still trips after some amount of time though never immediately, typically after an hour or so (sometimes more, sometimes less).
There are no GFCI outlets, and the breaker doesn't seem to be AFCI.
Is there anything I can do to further isolate the problem? Most likely at this point it's beyond my capabilities, but I'd rather have the electrician spending time fixing, not diagnosing.
Here is a picture of the breaker:
Checked the change in the power draw after flipping on, only saw a change of .02 kW, so should be safe.
Went around with an IR temp gun, and none of the outlets were noticeably hot.
Outlet inspection will need some more free time to check...more coming I'm sure.
edit 2: breaker was also not hot directly after tripping. Starting outlet inspection soon
Edit 3: found a wire in an outlet wrapped in duct tape (the stuff I find in this house..). The wire was partially stripped underneath. I replaced that wire. Still going so far, half an hour later. I'll update in the morning if we're still going. Edit 4: that wasn't it lol It's probably electrician time, though in the meantime I'll do some research on working with breakers, they just seem scarier than outlets to me
Edit 5: Did some research and it's a lot easier than I expected, plus my whole-house shut-off is outside so significantly less dangerous than others. Once I can afford the time to shut off the whole house I'll test switching the wires.
