Our over-the-range microwave is currently configured for recirculating ventilation, which is less than ideal for many reasons (one of which being that it's over a gas range..). We discovered that there is ductwork behind the microwave that vents outside but the microwave was never connected, and the ductwork was not installed high enough for a typical rear-vented microwave exhaust (for reference, the house was built 2008). After pulling the microwave down, we found the first picture: looks like someone found there is ductwork and didn't explore any further? I decided to cut out more drywall to see what is going on. Turns out there is what appears to be a roughly 30x3.25" rectangular duct that extends down the wall about 2ft, then connects to an oval duct on the left side that makes its way out of the house. This interior wall is framed with 2x6 and OSB on the opposite side, most likely because it's a large vaulted ceiling behind here. They notched out the 2x6 to accommodate the rectangular ductwork. So, I'm looking for advice on the best way to vent my microwave here. I'd prefer to avoid cutting into the upper cabinet, so I'm leaning towards continuing the notch of the 2x6 all the way up to the cabinet (the 2x6 is not centered and would block one of the rear exhaust vents of the microwave), cutting out a 10x3.25" hole in the existing ductwork, and finding some way to attach and seal something like this. Does that make sense? Any alternative suggestions?
What does the exterior vent look like? (BTW, here's a non-FUBAR link: lowes.com/pd/…)– HuesmannCommented Oct 11, 2023 at 13:53
@Huesmann added a picture of the exterior vent (which has a mediocre damper). Also fixed the link, doh!– DanCommented Oct 11, 2023 at 17:49
I think your "snorkel" plan is reasonable. I sure hope that stud is non-structural (even though it's too late to do anything about it!) and that there's enough slack in the wires to push them to the side. That duct is clearly venting something, though. You may want to install a baffle(s) to prevent greasy air from "backflushing" to the duct's actual source.– HuesmannCommented Oct 12, 2023 at 12:59
I agree; I plan on taking out as little of the stud as possible, and the wires are actually back far enough that I probably don't even need to remove their staples. I was also planning on getting the proper damper for our microwave (amazon.com/Frigidaire-5304464343-Vent-Damper-Unit/dp/B00LXAS8YG) and giving some attention to the flap on the exterior. I forgot to mention that we validated this exhaust is connected to the ductwork using a leafblower :-D Thanks for the input!– DanCommented Oct 12, 2023 at 13:11
1Indeed. I ended up going forward with the "snorkel" last night and it worked! Thanks for the vote of confidence :-)– DanCommented Oct 17, 2023 at 12:56
Show 12 more comments
