I live in a house with some very old hardware, including these hinges which have started to squeak. The hinges don't appear to have a removable pin, as both of the end knuckles seem to be completely enclosed. I cannot locate any sort of seam or gap to remove the pin.
From the side:
The hinges seem to resemble these, which I found while poking around online:
How can I oil hinges like this? Do I need to take them off the door/frame? At that point, should I just replace the hinges? For what it's worth, the house is two hundred years old, although I highly doubt these hinges are.
