I would like to decant isopropyl gel fuel (i.e. Terraflame) into a safe container to burn in my fireplace.
In other words, I would like to create a fire bowl essentially in my indoor fireplace.
What materials would be safe to use? Ceramic? Concrete? EPS?
Thanks!
Some details: (1) Fake logs exist where you put the cans of gel fuel in. I don’t like how they look.
(2) My fireplace is a working one.
(3) The issue is that I want to burn wood and my spouse would prefer I did not because of indoor air quality. We are compromising with gel fuel.
    Burning wood and indoor air quality is a concern. A well designed fireplace/clean chimney, dry wood, and a outside source of combustion air can increase air quality. Concrete and a point heat source sometimes do not mix well. Ceramics/glass rated above the temperature of the burning gel should work as well as steel.
    Commented Sep 3, 2023 at 20:33
  • how is the terraflame can unsuitable?
    – Jasen
    Commented Sep 4, 2023 at 4:33
  • if there is a problem with indoor air quality there may be something wrong with your fireplace. what type of fireplace is it? photo?
    – Jasen
    Commented Sep 4, 2023 at 4:35
