I would like to know if my gas fireplace can burn wood within it safely. It is built into the wall, made of stone, and does not have any metal within it (apart from the pipe leading gas into the firebox). You can see the metal key and valve for starting the gas, and there is no ignition switch, so I light the fire by hand. The logs in the fireplace are decorative. It leads into a chimney.
I noticed here, which seems to have a similar setup, that it seems like a gas log fireplace, but I don't understand where to burn any wood (and it would seem unsafe to burn wood near the gas pipe). Would the gas line need to be capped?
Thank you!
