The door locks at my church are constantly being accidentally locked because the deadlatch button can latch by a simple push. Someone comes up and turns the handle, but inadvertently pushes the button - now it's locked. It can be unlocked from the inside by operating the handle, but requires someone to be inside.
The locks can be more securely locked by pushing the button in and turning it 90 degrees. It requires someone to unturn it 90 degrees.
Is there a way to disable the "push only" locking mechanism?
  • I'm not sure the brand. They look similar to this. homedepot.com/p/…
    – Chuck
    Aug 28 at 16:11
  • Got it. Yes, you're probably going to want to replace those with more appropriate hardware.
    – KMJ
    Aug 28 at 18:24
  • Please post a photo Aug 28 at 19:52
Replacing with more suitable locks (or non-locking set where appropriate) is likely the effective solution. Particularly for a quasi-public or commercial use such as a church.
I have disabled the internal lock button entirely by removing parts, so the door could only be locked/unlocked with a key, but I can't see removing the push function and retaining the turn function (since the turn function works by keeping the button pushed in.)
But one with only a turn function can be purchased. Providing only a turn function will not solve the problem if you have a prankster rather than accidental engagement. However, I think I have experienced doors where they would not close without turning the knob if they were locked (without the latch being a deadbolt.) But a clever prankster can defeat that...
  • When modifying such hardware you need to be extremely careful to not create a fire escape hazard. All automatic unlock and intuitive egress functionality must remain.
    Aug 28 at 16:30
  • Exiting the locked door from inside was tested. The only one I have experience with that would be a problem on is a non-push one that requires the button to be turned when exiting if locked. Disabling that button would be inappropriate. However, for a building use like a church, purchasing the correct type is certainly preferable.
    Aug 28 at 16:33
