How/where does one measure the PSI for your spray gun?
I have 100 psi coming in from the compressor. This pipes off through a pressure regulator (not a flow regulator). Let's say I set that at 35psi.
Then I have a pressure gauge at the spray gun. Do I adjust so that it's 35 PSI when the gun is spraying or when it's not spraying?
