I am thinking in mounting a washbasin into a 3mm steel plate. The plate will be painted in a Klein Blue.
Considering that it will get wet and that there won't be too much ventilation in the room... Which method do you think it would be best for painting it?
I am considering to do it myself.
I would use a two part epoxy paint, it's kind of sticky but if you apply it right you can use a roller.
  • You can apply it "right" with sprayer, brush or roller - at least we did...
    – Solar Mike
    Commented May 22, 2019 at 15:09
  • Buy a cheap foam roller and it should work fine
    – Machavity
    Commented May 22, 2019 at 15:40
You need to primer it with red oxide and for final painting, use odorless enamel. should be enough for your
  • Hello, and welcome to Home Improvement. Would you finish your answer? And, you should probably take our tour so you'll know how best to contribute here. Commented Jun 26, 2019 at 13:22
