I have a 1 inch gas line running down my attic with several branches. The branch going to water heater is a 1/2" branch. I need that to be 3/4" branch per code. However, the 1/2" branch is coming from a 1"x1/2"x3/4" tee.
Diagram of gas line layout:
Picture of gas line:
In order to change out the tee, I think I need to cut out the 29" section that's shown in my diagram and replace that section with a new pipe that's about 24" in length, a right/left coupling, and a 4" right/left nipple. However, I'm concerned ill need to get a really really precise length for that new 1" line, because it need it to thread into the left/right coupler and the existing tee before it. I easily remove the 1/2" line by unscrewing it as it just comes down the top plate for the wall and to the stub out.
Can I just get home depot to thread a new pipe section for me? And, if it's not the size I really want, just go back and get a new one threaded?
I may not have a lot of play in the lines here because I'm connecting at the halfway point of an existing system. Thoughts?
My thought was to turn off the gas supply, run my stove (furthest appliance from meter) until no more gas is coming out, check other appliances to make sure they aren't getting gas, then cut into the 1" line with a sawzall. Then, after all my work is done, turn the gas on, check for leaks with the spray method and a gas sniffer like this.
I want to hire this out but it's really hard to get a contractor to come out. It seems like this job is too small for them and they're just not interested.
