I'm planning to get a 100 amp sub panel installed in my garage but got conflicting opinions on a point from different master electricians. The point is one electrician is saying it's a must to separate ground and neutrals in the main panel before the sub panel is installed while the other says that's not needed. I know that ground and neutrals have to be separated in the sub panel per NEC code (which both electricians agreed to). The distance between the main and subpanel is going to be around 40ft.
Any suggestions or thoughts on this?
