I am in Ireland. I have a semi-detached two storey house. On the ground floror, on room has a suspended timber floor while others have a concrete floor. And the room with a suspended timber floor is the coldest in the house, with draught from below the floor clearly happening.
I am considering putting insulation above the floorboards, as taking them up is a huge and risky job. However, I can't work out just how to stop the draughts. Foam-based floor insulation appears to require an expansion space around it, and nothing would stop air from flowing in that expansion space. I would not trust a mere polythene membrane to stay intact long-term (in fact one appears to be installed in the existing floor). So what kind of insulation layer can I use to make the floor airtight?
I would hope that an airtight floor does not create a rot issue because the floor is still ventilated from below.
