I have a 150w low voltage (DC) landscape lighting system (15v) but I'm only using maybe 50w of it. I also have a 400w solar array connected to a 40a MPPT controller that keeps a 50ah LiFePO4 battery charged...unless it's winter with long nights and subsequent cloudy days.
I'm curious if it would be feasible to run a leg from my landscape lighting setup to the solar array for supplemental charging? I have it on a dusk/dawn timer so the thought is that it would charge the battery overnight and if it's cloudy the following day the battery will have enough power stored to last until the next charging (given that it's cloudy and the solar panels can't charge).
My charging voltage is 14.4v. Is this pretty straight forward or a no-no? I would need to also have a diode so that the power from the battery doesn't flow back the other way.
Equipment brands/models:
- Renogy Rover Li 40a MPPT solar charge controller (https://www.renogy.com/rover-li-40-amp-mppt-solar-charge-controller/)
- Volt 150w transformer https://www.voltlighting.com/150w-slim-line-led-transformer
- Weize 50ah LiFePO4 battery https://www.amazon.com/gp/product/B0BGS1KTVZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
