As you can see, the pivot point for my door is away from the wall. From what I can see on the top there is simply a hole where there is a pin-like securing mechanism. I cannot tell how the door is attached at the bottom.
Everything I've found online has details on how to repair this problem has the hinge at the wall.
Any guidance would be appreciated, I would obviously like to be able to fix it myself but really unsure where to start.
Thank you :)
