My ring wired doorbell is not getting enough power. The transformer has multiple options but is currently set at 8V 20VA and the chime state 16VAC 10VA.
Can I switch the load of the transformer to 16V 30VA?
Sign up to join this communityMy ring wired doorbell is not getting enough power. The transformer has multiple options but is currently set at 8V 20VA and the chime state 16VAC 10VA.
Sure, go ahead and switch it to the 16 volt tap. The chime only cares about the voltage and having enough capacity in volt-amps to run it properly. If you have more capacity than you need it won't hurt anything in the doorbell circuit.
From the installation guide:
Your Doorbell Wired is compatible with doorbell systems supplying 10–24 volts AC, at 50 or 60Hz, 40VA max. The AC connector is the class 2 energy source.
Change it to 16.
