I installed one of those fancy new Ring doorbells (the video / WiFi connected doodads) and it keeps repeating my doorbell chime. When you press the button to "Ring" me, the doorbell chime rings and the the app initiates a video call to my phone. Until I accept, reject, or let the video call timeout... my doorbell chime keeps repeating (dingDong, [pause], dingDong, [pause], dingDong, [pause], dingDong, [pause]. ... ). This is a huge annoyance if I'm at home and just walk to the door. Until the call times out I have to shout overtop of the "dingDong dingDong dingDong...".
I confirmed it works as you would expect it to with an old fashioned button + diode. (e.g. 1 press = 1 dingDong... hold the button down = repeating dingDong). In a nutshell, the Ring is acting like I'm holding the button down.
I drew a diagram of the circuit, and as far as I can tell everything is correct.
- Circuit is: Transformer > Ring > Diode > Ring > Chime > Transformer
- Transformer is a 16v transformer, chime is for 16v transformers
- Transformer reads 19.4v without load... but I understand that to be expected after some research on the net
I've tried a new transformer, a new chime, and a new diode... all do the same thing. I have the diode wired up so the stripe faces the chime... which the Ring instructions say to do.
Any thoughts? I can't be the only idiot in the world who can't figure this out.
