I have a Kenmore 625.383560 water softener (WS). It looks to be the most generic WS on the planet that every house has.
I have set my pressure at 70 psi using the regulator on the house supply line. If I bypass my WS (using the bypass valve), I can open all approx. 6 faucets in the house and they dont visibly change flow/pressure at all.
However, if I put the WS back into service, I can really only use one faucet at a time. Some faucet combinations are worse in terms of loss of pressure, but I assume this variation is due to the layout of the pipes. eg I will probably get more change to the faucet furthest from the supply if I open a second one that is much closer to the supply.
I have cleaned the turbine/flow meter of the WS as it was stuck due to a small piece of debris. I have cleaned out the venturi as well. Neither looked to be in bad shape or dirty (other than that one piece of debris). I had a quick look at the upper "distributor" (the basket that sits at the top inside the resin tank), and that seemed fine at least from the outside. I didnt remove it inspect further.
There doesn't seem to be much else that could be wrong other than the resin needs to be replaced. However, this will be a substantially bigger job than what I have done so far.
So I'm hoping someone can either tell me what else I should check, or confirm that this is a problem that would be fixed by replacing the resin.
Date code on the unit reads 06221... 2006 seems too old, but 2021 is definitely not right.
EDIT: Onboard WS computer says that it has had electrical power for 5880 days total (16 yrs), and performed 1578 recharges (equivalent to 10 yrs at 3 recharges per week).
