I'm trying to figure out which is the correct mating angle out of Option A and Option B seen below (or perhaps something else different altogether) to properly help support the spreader beam using knee braces. Options C and D are another possible route but I'd strongly prefer option A and B if they aren't significantly inferior since I've done some work towards that end and bought some stuff already.
A challenge arises because the knee braces must be at an angle due to the tree lean and I can't just make a simple 90+45 degree tri-beam / double knee brace. I can do it but with the drawbacks as seen in options C and D.
(NOTE: the angles of the knee brace in option A and B is really more like half as severe of an angle as it looks)
