I'm planning to build a 2-tree treehouse and will be constructing tri-beam supports as seen in this video (or more accurately each side will be braced to the tree separately due to slight lean, but the same idea applies for the purposes of this question).
I was wondering what the best way is to screw the lags in to secure the brace to the top spreader beam? The video says to do them perpendicular to the top spreader beam but I wanted to check if anyone has different thoughts (such as perpendicular to the braces for example)
