I have the AC blower in the attic and my attic gets extremely hot. One side of the house has regular 8 foot ceilings while the other has cathedral ceilings. Some of duct work that runs in the attic is very close to the roof sheathing, since there isn’t much space. My roof shingles are black and the sun beats on them all day long. The attic has very little ventilation, I believe I have a small vent ridge but no side vents and possibly no soffit vents either. The house was built in the early 90's.
While testing my delta T at the return and registers, on the low ceiling side I get about 13/15 difference, but on the high ceiling side its less. The AC on the high ceiling side struggles to stay cold. This leads to my questions and concerns.
As far as I can tell the duct work is using R3 maybe 6 insulation, see attached pictures, the blower unit itself has a grey cover over where the coils are. It does have some gaps on the insulation but it’s not leaking air and I taped it up as much as I could. I’m concerned that the air coming out of the registers is not cold enough because of the lack of insulation on the ducts since the attic is very hot. I did check for the freon levels and they where fine.
The short duct runs have a nice flow with cold air but the long duct runs have a noticeable difference in temperature. On some of the long duct runs the flow is also weak, which I assume is either a leak I’m not aware or kink.
Should I replace the ducts with R8 ducts? This will not be easy due to the low crawl space.
Should I add R8 insulation between the roof rafters?
Should I add soffit vents?
Do I need to insulate my suction line in the attic ? I insulated it going to the compressor.
I’m basically looking from recommendation from the experts on here on what I can do to improve efficiency and wanted to know if the hot attic, lack of insulation and venting is an issue on the air temp coming out of the registers especially on long runs. What is the biggest change I can do that will make the biggest difference?
