See attached picture of my dining table surface. How can I fix scratches (shown by red arrows) and make it look new again ?
Do I need to stain it again ?
Sign up to join this communitySee attached picture of my dining table surface. How can I fix scratches (shown by red arrows) and make it look new again ?
If you want it to look like new, you're in for some work. You'll need to sand it down completely. Those orbital sanders work well for this but you'll need a hand sander for the fine grit. Start out with a medium grit,150, and finish off with 250 to 300. Thoroughly clean off and then apply the stain, looks like walnut. Then apply at least three or more coats of polyurethane. You'll have to decide the sheen level you want. Follow the directions on the cans of stain and polyurethane that you decide to use.
