I have a shower that has some kind of black mold around the existing caulk. I plan to remove it and recaulk. Following this video I know I need to:
  • use painters tape to create a strip for caulk
  • use caulk designed for baths
  • remove the tape when caulk is wet
And following this post I see I need to be sure to totally fill the crack: How to avoid mold in shower caulk?
This post advises using latex caulking Do I need to remove this enclosed shower and check for mold?
Anything else I should know? I have never done this before.
This is one of those problems that so hard to solve. Silicone, latex... I've tried them all, and all eventually allow mildew and mold to grow. Caulk needs to be redone regularly (like every 10 years, no matter what the tube says)... it may seem gross, but it's not going to harm you.
So to truly get rid of it (for awhile), you need to remove all the old caulk that you can. The black mold "around" the caulk is probably mold working its way in from the edges.
So the first step is scraping that caulk out as completely as you can, and the trick is that you have to use tools that won't hurt the tile.
There is a magic tool out there, and you can usually get them for free. The tool is Formica samples (or any laminated counter-top material). This is one of the greatest unknown scraping tools... it's like a fingernail on steroids. And it can be shaped and sharpened with a mill bastard file as needed.
It's an extremely hard laminate of paper and adhesive under pressure... go to HD or Lowes and grab a few smooth (not textured) samples (they usually don't charge you, even when there's a sign saying 50¢ a sample or something).
Start working at the caulk edges with this... FINISH SIDE AGAINST THE TILE (not the brown side), and pull as much out as you can in full strips. You may be surprised at how easily it comes out, especially if it's a decade old or more. The goal is to reveal the gap that the original caulk tried to fill.
If you're as obsessive as I, you can use an abrasive pad for the remnants, perhaps with the hand cleaner Gojo (magic stuff... it has a grit that really helps... it's an automotive hand cleaner, but we use it for a lot of things). Another of my favorite items for tasks like this is copper wool (not steel wool – that would likely damage the tile surface, and you DON'T want that. Copper is a much softer metal than steel.
After you've removed all the old caulk that you can, it's time to sterilize the area as much as you can (an impossible task unless they used epoxy grout).
So a lot of people use bleach... I've already suggested Gojo and copper wool or a brass brush, but there is something more effective than bleach... it's called RMR-86 Pro, available on Amazon (I have no connection to the company whatsoever, but if you can't tell yet that I'm particular about stuff then so be it). It really is amazing, and it really is probably toxic... mainly to your eyes, so use this with Goggles and a good mask (or hold your breath and squint like we do, but we're old ...) It's the best final step.
Oh... bonus suggestion... the best shower glass cleaner by far is Cerama Bryte... the ceramic stove-top cleaner. Cuts through soap scum and water stains like magic.
Hope that helps... and when I've said "we" I mean myself and amazing wife.
  • I will look for the formica samples! But if you can't find those, they make plastic razor blades that I've found to work well for scraping caulk from acrylic or other delicate surfaces.
    – Drew
    Commented Jun 9 at 12:44
Your sequence of operation is good. If it were me the day or so before doing the caulking and after thoroughly cleaning it using either bleach or hydrogen peroxide to kill the mold. I prefer using 3.0% to 3.5% concentration hydrogen peroxide to clean, it does not smell so bad. I do this by putting the peroxide into a spray bottle then spray the moldy surface completely to saturate the area with hydrogen peroxide and scrub it with a brush and spray again. Let it set for at least 15 minutes they dry completely with paper towels. I would then place a small fan to blow over the area to be sure it is completely dry for a day or so before caulking. Be sure to use a new bottle of hydrogen peroxide, it fades fast when opened.
