I'm replacing my two ceiling fans (same circuit, single switch). I didn't pay attention to how the wires were connected in the first ceiling box, and now I need help.
I've identified the switch as being wired as a loop switch, as the white wire coming from the switch is marked with black tape. I've identified another cable as my Load (continuing to ceiling box #2), another cable coming from the power supply. There is another set of black and white wire coming from the same direction as the switch, and it also has a marked white wire. So, I have a total of four sets of wires coming into the ceiling box, but I only know what 3 are. Is the other set another circuit that's been wired as a loop switch as well? I'm so confused.p..
I've tried wiring the new ceiling fan assuming that the cable from the switch was a loop switch, and tested the second one containing the other marked white wire as if it was carrying load to an an outlet. Tried the breaker. I haven't tried anything else. I figured I'd see if I could get some advice here before trying anything else.
