We recently purchased a ~20 year old house with no disclosed history of flooding.
Over the winter season, we've seen significant rainfall three times. Each storm, we've seen a substantial flood in our basement.
After the first flood, we engaged insurance, who brought in restoration services. The folks from that company dug up flooring after the second flood and discovered a very wet backwater valve pit. Pictured:
Backwater valve basin showing ~1/4" of water.
After the mold abatement and mitigation had been completed, we decided to leave the basement in disarray until another storm came to prove that the backwater valve pit was the source of our flooding problem.
Indeed, this past weekend we had ~100mm of rain, and the pit flooded. Luckily we minimized the amount of water taken in by opening up the backwater valve lid and the sewer system was able to take in the water. It drained all day at a high rate:
A video of water underneath the basement slab draining into the city sewer via the backwater valve access
A slight tangent: before we opened the lid, we saw seepage around the seams of our foundation and a few other points in the basement (around the grout of a toilet, around some now-sealed floor drains). When we opened the lid and let the water underneath our basement floor slab drain into the city sewer, the seepage stopped.
We will engage contractors on this project, but I thought I'd ask here, too:
  1. What could be causing this pit to flood now, and not before?
  2. What would you do to prevent it from flooding in the future?
  3. If we seal this leak, we won't have a way of draining the water under the basement floor slab... do you think the seepage we started to see will become a problem?
On (2): the house's eavestroughs and downspouts all seem to drain directly into underground drainage systems, so the first thing we plan to do is add elbows to these and direct the water away from the house.
We are also considering adding a sump pump—we do not currently have one.
Thanks in advance!
9
    You seem to be doing exactly what needs to be done ... figure out where the water is coming from, and arrange for it to go somewhere else. All the things I would have suggested are exactly the ones you are pursuing or contemplating. You may never know why this is happening now and not before ... if that is even true.
    – jay613
    Feb 23, 2022 at 13:34
    That's a lot of water in the vid! FInd out if you have separate waste and storm water systems in your street or combined. If separate find out which one that cover is related to, and find out if you're allowed to feed storm water into the waste system. If not, a sump pit in that location and a pipe that carries it somewhere downhill from your house is what you need.
    – jay613
    Feb 23, 2022 at 13:42
    Maybe there is a sump pump somewhere else, also hidden by flooring, that stopped working or was disconnected recently. (Trying to answer "why now" with wild guessing.)
    – jay613
    Feb 23, 2022 at 13:43
    In case it's not obvious: Opening the access door to a sewage backflow prevention system should not be your long term plan for controlling the flow of storm water during the precise times, ie storms, when you most need the backflow prevention !!!
    – jay613
    Feb 23, 2022 at 14:57
    If that is a back flow device they do need servicing. Like other valves in nasty environments they may be fine for 10 years then start failing when they had never failed before. It sounds like you are taking the correct steps but make sure to get the valve on a regular service cycle weather it is yearly or every other year but cleaning in the summer / fall when the water table is lower and less chance of problems is when I clean them, nobody wants to clean them or likes it but if not maintained the worse case of a flood is probably end result
    Feb 23, 2022 at 20:19
There's two possibilities here, and neither is a simple fix
  1. Your drainage ecosystem (weeping tile, grading, gutters, etc) has issues
  2. You have groundwater backing up through the foundation
The weeping tile should be your first stop here, because you'll want to ensure this system isn't contributing to the problem. I don't think this is your entire problem, but we'll discuss that in a second. If you want a DIY first step, try digging by the wall next to your basement. You'll need to dig all the way down to the footing, which is where your weeping tile should be. Be careful as this could be actual ceramic tile. Modern versions are corrugated ABS pipe with holes covered by a "sock" to limit dirt intrusion. Either way, you don't want to damage the existing weepers. Hopefully it's there and working. You'll need to look inside to make sure it's not clogged.
Next, check the grading of your house. When these torrential rains come, does water pile up anywhere on the surface near your basement wall? Do you have proper gutters to channel the roof rain water away from your foundation as well? Last, but not least, you might want to add a waterproof membrane to the foundation walls. That's more of a pro job at this point (requires you to excavate your entire footing), but there's plenty of products that are designed to keep the water from penetrating the sides.
Once you have confirmed you have adequate drainage from the surface water, you'll move on to the more serious problem: ground water.
Ground water is beyond any real DIY help, because you have water sitting in the ground beneath your house (my bet is your house is in a lower part of your neighborhood). When it rains sufficiently, the ground (which is absorbing the water) can raise the water table in the ground such that it now touches your basement floor. Since it's concrete, it can easily wick through and flood the basement. The fix here is you excavate the floor and add drainage pipes inside the floor itself. They catch the water and channel it to a drainage basin, where a sump pump sits. The pump then watches the water level in the basin and, when it reaches a certain level, it engages to dump the water outside (these should not drain to your sewer line). That's a pretty involved process to try and do yourself. You'll want a foundation specialist to look at it and do any necessary tests and work on this.
On the upside, they did at least add a sewage backwater valve. That ensures an overwhelmed sewer line isn't your culprit here.
  • Thank you. I estimate that it's a bit of both (1) and (2). Groundwater's building up possibly because the drainage ecosystem is failing somehow. (edit: hit enter too early.) Grading seems okay—we have a lot of snow down, so it's tough to tell exactly, but we don't see pooling around the foundation at all. The water we're seeing in this basin seems to flow in from the sides of the foundation, near a downspout. Hence why redirecting drainage is our step 1. Last: I'm hopeful a sump just in this room will save us, because we aren't seeing seepage anywhere else!
    – glassbrick
    Feb 23, 2022 at 14:11
