We bought our 20 year old house in Fishers, IN (northeast Indy suburb) this past summer. Three days after moving in, we had the last of the bad summer storms. One of the pumps in our Triple Safe sump system had failed, and we had about 2–3 feet of carpet along the entire east wall saturated. In addition to sump overflow, we also saw evidence of water entering between the wall and slab. We decided to replace 2/3 of the interior drain tile.
Once that was opened up, they discovered our footer cracked in multiple locations, separating from the wall. 9 low profile piers later, the job was completed and restoration in place.
Christmas weekend was rather wet. We were out of town and when we got home we realized that power had been lost at some point. No problem, though, because we have a standby generator (never had one before). Well, the standby generator didn't start because whoever touched it last put the lid on backwards, choking the engine of air. This time, the entire carpet was soaked.
We've now installed a new (better) generator and put both of the AC pumps in the basement on it (only one was on previously). Before we do any restoration, I want to be sure we've got things figured out.
Water is entering our sump pit every 12 seconds (from the time the primary pump shuts off to the time it starts again). 12 seconds!
I've unplugged the pumps to see what happens. The flow hits a point of stasis (or at least slows significantly) maybe 3–4 inches below the level of the slab.
Has anyone had experience with that much flow?
The sump discharges to a 4" PVC pipe that goes directly to a storm beehive about 15–20 feet away in my yard.
I am at a loss. I feel duped by the seller, duped by the home inspector, and we're left with 1/3 less of the house that we bought.
Any help or advice anyone can offer is appreciated.
