We had some work done in a room with a chandelier lamp. To get it out of the way, they raised it up using a couple of plastic cable ties through its chain and left with it like that. I figured it was no big deal to undo - I just had to cut the ties while holding onto the lamp so it wouldn't drop then screw in the top cover plate. I'm not sure what I did wrong but being the klutz that I am when I cut the second tie the lamp dropped about a foot and it's fairly heavy.
When I went to secure the cover plate I noticed that the metal bar to which the lamp is attached is bent, as shown in the photo. I hadn't looked closely before so I can't say for sure that it hasn't always been like that but I assume it's probably because of what I did. I lifted the lamp a few inches to take the weight off the bar and it felt like it was securely in place as nothing seemed loose.
So disaster averted or is this something that should be addressed? Thanks.
