I am installing a hanging light in the kitchen. Initially it was a GX24 4 pin bulb socket. As you can see in pic, there are 4 wires, 2 pairs of reds (hot) and 2 pairs of blue (neutral). 2 reds were connected to one side of gx24 socket and 2 blues were on the other side. They all had separate connections
I clipped one red and one blue and connected to the hanging light wire but it is not working.
When I tested hot/neutral wires, I was only seeing reading on red but only ~23 volts.
Now, I am thinking this single wire is not sending enough volt. Can I connect two reds to each other and then connect to the hanging light single cables and same for neutrals.
Is combining possible and safe in this case?
Photo of the box in the ceiling:
Thanks
