New LED fixture has Black, White, Green (Hot, Neutral, Ground). Box has two black wires connected to each other, two grounds connected to each other, two whites connected to existing socket and one red connected to socket. I am guessing that the red is the hot from the switch and the 2 whites connect to the single white on the new fixture.
Does this seem right? I haunt the Computer area, first-timer over here.
