I am working, with full permits from the city and future planned inspections of course, as an owner builder for the following projects:
- construction of a detached garage, where I need a 200A service for:
- car chargers
- I have two large welders, CNC plasma cutting, big compressor, plus other 240VAC machines through VFD's
- 18kW tankless electric heater, as I will have a full bathroom with sink and shower
- swimming pool, where I need a 100A service for:
- 240VAC pump
- 5HP swimming current generator
- (future) heat pump
- BBQ area, where I need a 100A service:
- 13kW tankless electric water heater
- (future) if I decide to put in a ADU (basically my state allows the construction of a second dwelling in the lot)
In the list above, I only included the biggest stuff, not counting regular 110V outlets and lights.
Right now, at the meter (PG&E, California) I have one single breaker, and there is a subpanel in the garage that has the breakers for the whole house.
What I would like to do is to get rid of that and have a main panel next to (or integrated with?) the meter with the capability to feed few (6? 8?) "big breakers" that will in turn feed the subpanels mentioned earlier. (please correct my terminology here if it's inaccurate). All the utilities are buried and are fed from below.
I am quite confused by the selection of panels that I can find online and struggle to find real technical data, maybe with a picture, to understand what model would satisfy my needs. I want good products, that use copper, higher end if reasonable:
- "main" panel with few breakers
- 2 x 100A, outdoors rated subpanels
- 1 x 200A, indoors subpanel
How do I choose one, or at least what are the elements I need to consider to narrow the solution space?
