We live in corner lot with 20-24 ft drop in elevation and plan on doing a home addition requiring heavy equipment. There’s a cedar fence around perimeter of entire lot. Currently only way for vehicles to drive in to backyard is to go up a 4 ft tall rock staircase -3 steps- through a standard 4 ft wide gate beside driveway.
Since that’s probably not feasible would turning a section of fence in to gate behind stop sign work? How wide will gate need to be?
House and driveway in blue below. Trees in green.
rough drawing
    Somewhere in the 20 - 30' range, depending if the vehicles need to turn onto the road. The best I can suggest is see what the contractor needs he/she is the best judge.
    – Gil
    Commented Jul 17, 2021 at 15:21
    Do you need the fence? Will your llamas get lloose and roam the neighborhood?
    – Willk
    Commented Jul 17, 2021 at 17:46
  • @Willk ;-) they will
    – Danger14
    Commented Jul 17, 2021 at 19:18
Most all heavy equipment is under 10’ -12’ wide max and that requires wide load so it depends how big a tracked shovel or Track hoe you might need. To tell the truth most homes won’t need more than a extend-a- hoe back hoe and these can fit through a 8’ opening mini Cranes again are only 8-9’ wide so in reality the heavy equipment needed for a home will be fine at 10’.
  • or 9'9" (which is what you get when you remove the fence between two ordinary 10' spaced posts.
    – Jasen
    Commented Jul 18, 2021 at 11:40
