I have 2 cabinets to repair, both were damaged by water.
One, I need to replace the wood at the kickspace. It is about 1/4 inch thick.
The other cabinets had had enough water to damage the veneer on the side, but not the underlying wood. Is there a think veneer I can glue to the side of the cabinet (there is enough trim to hide the installation that is 1/4 inch or so)
If these products exist where can I find them? I have been searching online with no luck.
  • A simple search showed many places to buy veneer.
    Apr 26, 2021 at 18:25
    Are you sure the underlying wood is good? Usually when veneer is damaged like that it's because the cabinet's made of particle board which collapses when exposed to water/moisture.
    – JACK
    Apr 26, 2021 at 18:28
    Does this answer your question? How to deal with this water damage
    Apr 26, 2021 at 18:41
