I have assembled a TV cabinet / TV table. It is made of a metal frame, with "rings" on the inside of the frame on which the table plates rest.
The first image shows one of the "rings", the second picture shows the assembled table without the plate that goes on top of it. The third image shows the page from the instruction that shows how the top plate should be attached to the frame.
According to the instruction manual you are supposed to put a screw through the ring and screw it into the bottom of the plate (see image 3). None of the four plates have holes however, on either side. On the first page of the instructions a screwdriver is shown, but no drill. It looks like the production company forgot to drill the holes.
To me it seems like the screws would only make a difference when moving the entire table as you could lift them out of the frame when carrying it. They should be irrelevant in terms of stability and maximum supported weight (40 kg according to the website) as long as it is just standing there.
Do I need to get a drill and make the holes myself so I can screw the plate to the frame or can I use it safely without the screws? Is there a risk that it may break / fall apart when I put things on it due to the missing screws?
The plate itself does not really move even without the screws, it fits exactly into the metal frame.
