I messed up! I was replacing two light fittings that are both controlled from 2 two way switches.
I did not make a note of the existing connections before I removed the old fittings (noob mistake I know).
Anyway I connected the 2 browns(live) together and the two blues(neutral) together and the 2 yellows(earth) together. When I switched back on the lights worked but now are linked to another light. (Switching that light on switches these two on and switching these two on switches the other light on)
I realise I need a "loop" for the switch - but not sure what needs to go to the fixture and what needs to be joined together. B
There are two 3 core cables going to each fitting. Here is a picture of what I currently have for both fittings - can anyone tell me what what I need to change?
