What. Do. I. Do. With. This.
All of my network, cable, and phone wires run to this white box.
I don't know what this box is called.
There's a couple of power outlets at the bottom, within the box. The black block thing is used for phone, and has some kind of what I think is a 1-N cable expander (I assume to take in coming cable and route it to a bunch of rooms) bolted to it.
There's a cable modem and wifi router in here, one is just sitting on the bottom. It's just a free standing black box. The other is essentially dangling from a screw shoved in to one of the white box holes.
I have a power strip hanging outside the bottom, since if the internet goes whacky, it's easier to just click the power strip than to unplug bricks or barrel plugs. There's also a small satellite TV thing hanging here somewhere.
This is certainly something specifically designed to wrangle this mess, I just don't know how to approach it. My fantasy is to turn this in to a something I could route with patch cables. But, I don't know what to look for to plug in to this thing.
Is that an unreasonable expectation? Are there things that I can use to perhaps mount these small boxes, and the power strip? Add network panels (I'm not a network person, so the vocabulary eludes me) for the phone and network? Can I do the same for the BNC cable connections?
Or should I just strive to shove all of this in to the box, and hope to never have to open it again.
I just don't know what this stuff is called, what to look for, etc. When I see folks talking about these kinds of things (I think), they're mounting computer racks for servers and routers and what not. Far too big and too deep for what this is.
Amusingly, the person who actually wired this in my home stopped doing that work and started driving a dump truck (for his family business) delivering gravel for landscaping, and he happened to deliver some for me. We talked, but he wasn't helpful in his advice as to what I should do.
So, I'm looking for direction and suggestions on what I can do to neaten this mess up beyond color matching the velcro wraps. If I were to hire a professional for this, what kind of person would I search for?
    Believe it or not, that's pretty dang tidy. Unless you have reason to routinely reconfigure things in there I'd close the door.
    Dec 8, 2020 at 22:16
    You're in the realm of aesthetics and personal preference, neither of which we really tackle here, but you'd probably hire an obsessive network tech to do what you're after. Most electricians aren't low-voltage specialists in my experience, and even fewer care enough to make art out of your panel.
    Dec 8, 2020 at 22:21
  • There are smaller patch panels but it's hard to tell what can fit inside that bay. If I were you, I'd start by wrapping those cable loops so they don't hang down so far, and see if that makes you a little happier with things. Try not to use too many plastic wire ties; they can wear on the outer jackets of your cables over a long period of time. Velcro wraps are better. Dec 8, 2020 at 22:49
  • I agree with Isherwood both neat and many residential electricians do not have the experience to do things right or care to do neatly, as far as ty wraps or zip ties you will find them in commercial jobs 1000:1 compared to Velcro.
    Dec 8, 2020 at 23:26
It's called a structured media enclosure and it does actually look decent. Granted, it's only half-assembled -- the second half of the project is the part that costs $$. If you wanted to hire a pro you'd be looking for an audio-video integrator - somebody that does home theaters and home automation systems. A contractor who does network cabling in commercial offices could do it well too. Either way, though, these pros usually work on systems far bigger and more expensive than what you have here.
The UTP network/phone cable are easy to deal with. They're most likely to be CAT5e or CAT6; check the jacket of the cables for marks that indicate the type. Every manufacturer of enclosures also offers a line of patch panels designed to fit. You can, of course, choose some other patch panel that suits you and devise your own mounting scheme. The blue and white cables down the right side look like they're all UTP and could be terminated to patch panels like these. You could then use short patch cables from the panel to your WiFi router or Ethernet switch. Following is an example of one made by Leviton with photo credit to BIoT Canada. Making one look like this is definitely art and it's not inexpensive.
Leviton structured media panel
The coax cables are a little more difficult. There are patch panels available for these too, but coax patch cables are annoying and coax cables have to be interconnected with a gadget called a splitter.
If you aren't interested in the nuance of splitting coax signals skip this paragraph.. A splitter literally divides the incoming electrical energy among its output ports. A 1-to-4 splitter sends one quarter of the energy to each of the outputs; a 1-to-8 splitter sends one eighth to each output. Depending on the signal source (the signal's strength, actually -- whether it comes from cable TV service versus over-the-air broadcast antenna, for example) it becomes increasingly necessary to also add an amplifier ("signal booster") with higher-count splits. Also, because of electrical signal quality issues, it can be important to use a "terminator" cap on unused ports. This applies whether the port at the splitter is unused, or a cable is attached but doesn't have any equipment (TV or tuner box) actually connected to it.
If a splitter or amplifier is used and the coax is also involved in a broadband Internet service then it's important to choose devices that are designed for bidirectional use so the messages from the cable modem can get back out to the cable provider.
So, for the coax, I vote to put F connectors on the ends of the cables actually in use and connect those directly to a splitter that has just enough ports. Leave the rest of the coax cables bundled neatly, maybe terminate them all just for possible future convenience, but don't bother with a patch panel or fully connecting every one of the cables to a splitter.
  • Greg you should mention that cable splitters take some of the signal unless there is a booster and this is why we only connect what is needed. A bunch of unused connections and everything has weak signal.
    Dec 8, 2020 at 23:19
  • I don't agree with the statement that " A bunch of unused connections and everything has weak signal". If you have a 1:n splitter, and leave m of those outputs open, that's better than terminating them with a 50 ohm load, from a down-stream signal strength standpoint. The one thing a termination plug does do is to close out the unused port and prevent any noise from coming back onto the signal.
    – SteveSh
    Dec 9, 2020 at 0:22
  • And how much an open (or unterminated) output of a splitter affects downstream signal level depends on the frequencies involved and length of the connections from the actual signal splitter (in the bowels of the unit) to the output. The longer they are (greater than a couple of inches at 1 GHz), and the more likely you are to see some deleterious effects.
    – SteveSh
    Dec 9, 2020 at 0:25
  • And do yourself a favor and put the patch panel (thing on top left in photo) near the bottom. That way, if a wire end takes damage and you have to re-terminate it, you can just move the patch panel up an inch to buy the needed length. This display model was fanatically "neatened" for show, and does not function. No working panel would ever be this neat... nor should it. Dec 9, 2020 at 18:41
  • Also, expect routers/modems to be outside this box, and nothing but hubs/switches in here. In this display/concept model, they chose an amazingly small cable modem (I have that model, in a box - Comcast won't let me use it anymore). However Comcast and AT&T (I have each at different sites) both forced me to take much larger boxes that won't fit in this panel, and they run much too hot to cool properly inside there. So expect to feed telephone/cable + 1 ethernet to some designated location with power where that gear will live. You only need 1 ethernet to the DSL/cable modem. Dec 9, 2020 at 18:45
