I have 20mm previously drilled holes in double thickness insulated plasterboard.
I think a toggle bolt will be the most appropriate, but I’m struggling to find something that will be appropriate given the thickness of the wall and the insulation.
Any recommendations welcome!
Edit: I’m hanging a 12.5kg mirror, but the large holes are already there.
  • Can you give us an idea of what you're trying to hang and the weight?
    – JACK
    Oct 11, 2020 at 18:03
These toggler anchors will work for thin to very thick walls.
You do not say what the insulation is, The insulation may be a factor in getting them to toggle into place properly. I sometimes use a wire to push fiberglall insulation aside a little so they sit properly.
I have posted several answers about installing these anchors read a few for info and tip/tricks.
https://diy.stackexchange.com/search?q=user%3A56737+toggler
use the nut of a toggle bolt but substitute threaded rod (or a longer machine screw) for the screw part.
    Hi. Your answers keep popping up on the "Low Quality Posts" review queue. Would you mind capitalizing, and even add a second or third sentence? Thanks. Oct 12, 2020 at 11:03
