Replacing 30 year old light switch with new light switch assembly need help with the wiring identification (-; thought this would be similar to replacing outlets but all the wires are black so I am at a loss. Thank you. New switch ..basic from Home Depot —one green two brass one black screw
2Switch you bought is not basic - it's a "3-way" - you can use it as a basic switch by ignoring one brass screw, but it will make your wiring task more confusing (as a novice) if the old switch is not a 3-Way (and it appears not to be, though the picture is not great for being more than 99% certain)– EcnerwalCommented Oct 5, 2020 at 14:11
Thank you anyway I figured it out even though it was old one was positive one was negative one was the ground they were all black just pay attention to where they are when you disconnect them and it will make sense on the reconnect but always ask a professional LOL– DIMDSCommented Oct 5, 2020 at 14:42
2There is no positive or negative in house wiring (it's alternating current), and it's almost certainly NOT the case that a black wire is ground; it is, as stated in the answer, very likely that the old switch has no explicit ground connection.– EcnerwalCommented Oct 5, 2020 at 15:01
1 Answer
Does not matter what color the wires are. With switches we see far more problems from people applying what they think they know about wire colors and the odd things that are common practice in switch wiring before the requirement to supply neutral to the switch came about. They unscrew everything and then can't make it work because they lost track of what went where.
All black is fine - just be sure to keep track of which black wires go where, and put them the same place on the new switch.
The old switch may not have a grounding (green) screw.
The old switch appears to be a two-terminal switch with one wire on one terminal and two wires on the other terminal. Mark, tape, or just don't disconnect all the wires so you keep track of which two go together.
Connect one wire to the black screw. (or one of the brass screws, but for the sake of a narrative that will work... lets stick with this.)
Connect the two wires to one of the brass screws. Leave the other brass screw empty, since you are replacing a two-terminal switch with a 3-way.
If you need to, connect a short wire to the two black wires that go together using a wirenut or approved splice block and connect that short wire ("pigtail") to one of the brass screws. This is better than using those "push-in" or "backstab" connections that your old switch seems to be wired with.
The green grounding screw should have a green or bare-wire pigtail attached that connects to the bare or green ground wires in the box, assuming you have ground wires (mid 1970's or 80's there should be.) If the box is metal, those should already be connected to the box, as well.
2Ecnerwal is being too kind and not ranting about the backstabs. Don't use them, they have a long history of causing trouble. +1– JACKCommented Oct 5, 2020 at 15:07
