I'm in the UK in an old house with fairly old wiring. In one room, I have a 5-bulb light fitting with LED bulbs. I've been battling for months a problem that they are not constant brightness - infrequently they dim for anywhere between .1s to 2s. It's like fingernails on a chalkboard to me and it's our main living room but I've run out of things to try.
Some further information:
- Similar bulbs and fittings in other rooms on the same lighting circuit without any issues
- I have changed the bulbs
- I have changed the switch (now it's a simple on/off not a dimmer)
- I have tested the fitting in a different location (wired to a plug) and it works fine
Initially I thought it was a problem with bulbs or with a new dimmer switch but swapping things around it seems to be this room specifically. I might be able to lessen the effect using incandescent bulbs as they have better smoothing, but we use this room a lot and I want to save on energy costs... and damnit I want it to work properly! That other things on the same circuit work fine is confusing.
What is likely to be causing this problem and how could I go about confirming this? What can I test?
