Does anyone know how I can remove this handle? There's no setscrew and it appears to be 1 piece. I tried to pry it off. The drain says it's a Kholer, not sure the drain matches the faucet.
4That appears to be a hex screw inside the open end. I believe that's a clamp that holds the outer part onto the stem. Did you try backing that out and seeing if you can remove the handle?– jwh20Commented May 18, 2020 at 19:33
it is staring you in the face– jsotolaCommented May 18, 2020 at 22:23
1Gotta give an up vote we have a clear photo and although the op may not have ever have seen an inset hex screw , the information needed is there to provide an answer @JWH20 make that an answer with some cautions and I will up vote.– Ed BealCommented May 18, 2020 at 22:28
Add a comment
1 Answer
Inside the end where you removed the handle extension there is a brass hex nut.
Loosen that with your hex wrench and you should be able to pull the handle off the stem.
Thanks, I'm going to try that. I didn't want to mess it up if I wasn't supposed to remove the nut. There's actually 2 of them , 1 on each side of the stem.– Tom ZakCommented May 19, 2020 at 20:19
