On a residence located about 20 feet from the ocean in a severe weather climate. I am contemplating putting stainless steel well sealed marine lights on the house for some exterior deck lighting and flood lighting.
If I use a step down transformer for converting 120V to 24V, I’m wondering if there is a special junction box that would allow me to split the box and be able to fit transformers in the box at each light ?
Or would it be better to step down the power for the entire circuit near the panel?
I don’t know if there’s a voltage drop problem but farthest fixture might be 120 feet from the panel.
The lights I’m replacing had aluminum housings and completely degraded from the salt over 15 years. Hoping there is also a gasket-ed stainless box as well out there.
Am I crazy to pursue this ?
