Context
I have a small covered patio illuminated by an unattractive wall-mounted CFL fixture. For an improved ambiance, I have hung a string of LED patio lights that are plugged into an exterior outlet.
I would like the convenience of being able to switch the light string on/off from the wall switch inside the patio door (currently wired to the CFL fixture), rather than reaching behind the patio furniture to get at the outlet. To that end, I would like to somehow power my LED light string from the circuit that powers the CFL fixture.
Below is a photo of the inside of the CFL enclosure for reference.
Constraints
I live in a condo building that has a by-law regarding alterations to the exterior of the building.
Obtain approval before altering a strata lot or common property. Before making an alteration to any of the following: the exterior of a building;
I'm looking into exactly what this means for my purposes, but I suspect a "temporary" solution is preferable to any permanent electrical changes.
Question
How can I safely wire up my LED light string to the existing CFL fixture, such that the light string (rather than the CFL) is controlled by the indoor switch?
Ideas
Some ideas I've considered, but am not sure how to evaluate:
- An adapter of some sort to adapt the CFL socket to a three pronged outlet, similar to this Amazon adapter. I haven't been able to find one for CFL sockets, and I suspect they don't exist.
- Splicing an outlet in parallel with the CFL fixture (on the 120VAC line, not the stepped up line into the CFL socket) and inside the CFL enclosure. Then just leaving the CFL unplugged.
- Replacing the fixture entirely with an external outlet. This is less ideal from the strata perspective.
