EMT has the merit of being protected from physical damage, but it will rust and requires special boxes and kit to prevent that.
PVC Sched 80 is also protected from physical damage, and, you can use Sched 80 and Sched 40 interchangeably (since the critical dimension, the OD of the pipe, is the same).
PVC conduit will degrade in the sun. It's sun resistant, but that only applies until the warranty expires :) Your best bet is to scuff-sand it with some 3M green Scotchbrite pad, then paint it with an alkyd primer and normal house topcoat.
