I have an older Black and Decker KR650RE reversible hammer drill. I need to replace the chuck however the screw on the inside seems damaged. How can I remove the chuck.
Any help much appreciated. Thanks!
Gently tap an old screwdriver in there and consider it may be a left-hand thread.
Worked for me in the past.
That damage is due to drill bits spinning in the past when not the chuck was not sufficiently tightened.
I just had the same issue and a friend suggested holding a screwdriver on the screw and tapping it with a hammer. It took a few attempts but eventually it loosened enough I was able to unscrew it (with left-hand thread).
