I'm planning a remodel in an appartment, and the way I see the space would work the best is when I bring a kitchen quite far away from the mainlines. And layout dictates that sink drain pipe should go in a concrete subfloor, which I estimate will be 8-10cm thick.
The pipe in the kitchen-side can go above the floor inside the cabinetry, but it must be underneath the floor in the hallway-side (that is drawn in yellowish and approximately 2.1 m long).
I'm also not perfectly sure how low it can be attached to the main drain (it's vertical and plastic), probably some millimeters (at least) in height would be lost there. So, if use 4cm diameter pipe and lay in with 4-6 cm incline it adds up to the subfloor thickness. But it adds up just in pure math. Is it reasonable enough for the real attempt?
The reason I ask is I must present a plan for authorities now, and then it would be impossible to place the kitchen in any other place and I would hate to lay the pipe without proper incline just to fit in, and then install a sink drain pump.
Also, should I use iron, or plastic tubes are fine to be laid within a concrete slab?
Thank you for your time and suggenstions!
floorplan
  • You should consult the contractor who will be doing the work. And, if you're thinking to do the work yourself, I'd be concerned. For instance, you're proposing cutting a substantial slot in your foundation slab; I'd be worried about its resulting weakness. Apr 4, 2020 at 18:11
  • Daniel, thank you for the concern. So far, I'm thinking to do that myself. But to be clear, I have proposed nothing of a sort: a load-bearing floor plate will remain untouched, the intention is to pour concerete subfloor over it, hiding pipes in it.
    – Dmitri K
    Apr 4, 2020 at 19:46
  • If so then we'll need a lot more info, and even with that info this question is probably too broad for our site. Let's see if any of our pros weigh in, though. Apr 4, 2020 at 19:53
  • Yep, let's do that and if question stands for a longer period, eventually I will write how the thing have played out.
    – Dmitri K
    Apr 4, 2020 at 20:00
You could install a laundry type pump system to pump the kitchen water overhead . I had one of these pump systems in a laundry area in an apartment I lived in and it worked perfectly. And, if you wanted to add a bath room or powder room they have systems that "pump up"for that too.
  • Oh, I haven't thought of that. Seems reasonable alternative
    – Dmitri K
    Apr 5, 2020 at 16:19
