I have a Frigidaire Professional Series 4300 series AquaSurge with Speed Clean. It seems to start running fine, but then intermittently pauses for varying lengths of time. This usually results in hot, steaming, sometimes-wet…dirty dishes. Sometimes it cleans fine, but this has turned into a rare occurrence. More often than not, the detergent tab can be found ejected but undissolved, somewhere at the bottom of the dishwasher.
I've tried troubleshooting this myself by sticking a camera and light inside and running a cycle. Here is what happened:
0:00 - set the program, shut the door, loud droning sound with nothing visible happening inside
1:00 - sound stops, and nothing happening
2:35 - opened door to have a look
2:55 - shut door and water immediately starts flowing into the dishwasher
4:25 - lower arm starts spinning and spraying
7:30 - upper arm starts spraying but not spinning, top mini arm is spinning and spraying
7:44 - water pressure of upper arm starts varying between normal and low, and top mini arm stops spinning and spraying
7:55 - water stops flowing out of upper arm
10:48 - bottom arm starts spinning / spraying again
12:20 - bottom arm stops, upper arm starts spraying (but not spinning), top arm is spinning / spraying
13:48 - upper and top arms stop abruptly and bottom arm starts shortly after
15:30 - bottom arm stops and upper arms going again
16:50 - upper arms stop, nothing happening
33:15 - my camera stops recording nothing
Any ideas what might be wrong with this thing, or what else I can try to get a better idea?
Per the manual,
It is normal for dishwasher to pause (no sound) when the wash action is switching between the lower and middle spray arms
but 17+ hours, yeah, somethings wrong. Hard to troubleshoot, could be the computer in the panel, some sensor. I think you need to get it serviced
It sounds like there's a plumbing problem. berhaps there's a blockages somewhere inside the dishwasher, or perhaps the pump is malfunctioning.
Start by checking all the easily accessable filters.
If you haven't tried it yet run a cycle with dishwasher cleaner.
equally it could be a defective sensor causing the cycle to pause or even skip steps.
