Just installed new GFCI. When I plug in a device it has power, then press test button and power drops out, then press reset button and power is back on. Everything appears to work EXCEPT no green led indicator - why??
    What make and model is said GFCI? Commented Mar 23, 2020 at 23:25
    Personally, I don't like the indicator lights on everything. What should be a perfectly dark room isn't any more. But if it is supposed to have that green light (as opposed to "my old GFCI did, so this one should have one to") then if the light doesn't come on that is a problem. Commented Mar 24, 2020 at 0:07
If it is supposed to turn green and doesn't, it is faulty. Replace it.
