I am trying to install a reverse osmosis RO system under the kitchen sink. The pipes are all metal (brass, I suppose but not sure). where can I install the drain saddle?
The instructions with the RO system and online videos/PDF all assume that the pipes are plastic/PVC etc. Is it OK to drill that 1/4" hole in the metal pipe or will the pipe be too thin and not hold the drain pipe properly?
Thanks much!
