I am installing a water filtration system under my kitchen sink. The filtration system requires a small drainage line to be drilled into the vertical drainage pipe from my disposal to the P-Trap (See attached picture).
Unfortunately my drainage pipe between my disposal and P-Trap is very short. I don't think there is enough room for the saddle bracket to fit. (The red "X" is where it would have to go).
My question is, would I be able to make the disposal drainage pipe longer to provide enough room to install the drainage saddle bracket? This would lower the P-Trap, so I am wondering if it would position the P-Trap too low from the wall drain opening to be effective?
I asked the company if the drainage line could be installed after the P-Trap on the horizontal pipe, and it would not be correct. If I were able to fit the saddle bracket on the vertical pipe where the red "X" is, the concern is that it could get clogged.
Thank you I appreciate the help!
