We moved in just shy of a year ago. In the past month these spots have been showing up- they are dry to the touch and only in our living room - on both the interior and exterior walls.
For reference the home was built in ‘92. THOUGHTS? Thanks so much!
  • what is the scale? Did you repaint after moving in?
    – depperm
    Commented Sep 6, 2019 at 13:25
    Are the spots in rows , like moisture causing screws or nails to rust? I am guessing at rusty fasteners because I can’t tell the scale had have seen this. If this is the case a schlack type of primer may be needed and repaint to keep the rust from bleeding through.
    Commented Sep 6, 2019 at 13:47
  • Hello, and welcome to Home Improvement. We'll need more information before we can help you. And, you should probably take our tour so you'll know how best to participate here. Commented Sep 6, 2019 at 13:48
  • What material are the walls made out of? This also looks like a wood knot bleeding through the paint.
    – JPhi1618
    Commented Sep 6, 2019 at 14:26
  • Did you ever find the cause? With no additional info we can’t provide much help and we really like to help those that ask. If you have found a solution it could help others if you post it as an answer and accept it.
    Commented Dec 15, 2019 at 0:11
