I am remodeling my bathroom and the "tile guy" removed my shower parts. The old Moen valve was still retained.
I put everything back in using new Moen shower kit
https://www.amazon.com/gp/product/B07H19B72Y/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
However, I could not figure out why turning the valve in either way did not turn on the water:
The water did not come in either of the position above.
What did I do wrong? Was there another shut off valve that I am not aware of?
Thanks.
  • Did you install a new valve or keep the old one, you say in different places, that you did both...
    – Solar Mike
    Commented Aug 28, 2019 at 8:37
  • I left the old valve in the wall. I think now it is a big mistake
    – HP.
    Commented Aug 29, 2019 at 2:33
When you turn that style of Moen control, it mixes hot water with cold to adjust the temperature; but first you need to pull out to get the water to flow...
  • Also, I am not convinced that you purchased the correct trim for your valve (modern trim vs. old-ass valve). Commented Aug 28, 2019 at 11:05
  • Yeah it was the pull out one. I totally forgot. So look like I need to change the valve. I assume that means the plumber need to remove the two tiles around that area. Messy job.
    – HP.
    Commented Aug 28, 2019 at 15:38
  • Easier to return the trim you bought and get the right trim... That is a good reliable valve model IMO... Commented Aug 29, 2019 at 2:39
  • We kinda don't like the pullout valve though. I totally forgot that. Also even if we go with pullout, there is no GOLD handle that the spouse wants...
    – HP.
    Commented Aug 29, 2019 at 2:40
