Pictured here is what I thought was a shower valve shutoff screw. There is another one on the other side of the valve. I turned the screws clockwise to tighten and shut off the water so I could replace the cartridge; however, they just kept turning without tightening. Are these not shower valve shutoff screws? Any advice?
Thanks!
  • Do you know the valve's make/model? Hopefully the manufacturer has some info on exactly what parts are where, and how to use them
    – Xen2050
    Commented Dec 26, 2023 at 15:56
Try turning the slots so they are vertical to turn off the water to the cartridge. That's how mine work. Then turn the slots horizontal to turn water back on.
  • 5
    In other words, those service stops are "ball valves" or something similar, and do not tighten.
    – kreemoweet
    Commented Dec 26, 2023 at 11:43
